Find the middle of a box
Is there a method to find the middle of a box using the SDK? I have a addin that randomly creates variously sized boxes and i want to ensure they are laid flat and that i can align the center of the bag with a frame.
Hello,You can compute it.☑️2024 - RobotStudio® User Group0
I am no math wiz, but could you clarify the question? As I see it, box implies a cube, 3D, while you mention lay flat, which makes me think of a 2d square.Lee Justice0
lemster68 said:I am no math wiz, but could you clarify the question? As I see it, box implies a cube, 3D, while you mention lay flat, which makes me think of a 2d square.
To do this I've created the box (Body.CreateSolidBox), then using Body.CenterOfGravity & Transformation(s) I am able to calculate where the nearest edge is on a 3D object to place a frame in the centre of the surface ensuring the frame created at the centre of the box is alway aligned with a frame. End result shown below;
So it looks like you have found a satisfactory solution? I realize reading what I posted how dumb I made myself look, half of width and half of length is center, duh!Lee Justice0
- 398 UpFeed
- 300 PowerPacs
- 336 IRC5
- 67 OmniCore
- 828 RAPID Programming
- 12 AppStudio
