Multitasking
AMEENA
What is the main difference between single cycle and continues cycle in Multitasking in ABB Robotstudio.
If your task is NORMAL, then I suppose it might have the same effect as the main task, but usually a background task will be SEMI-STATIC or STATIC and they would just run continuously regardless.Lee Justice5
OK.Thanks0
