Comparing posititions
I am working on a project and need to compare two positions, but can't figure out how to do it.
Thanks in advance!
It looks like it might work. Single step forward one line at a time so you can see the values and the evaluation of the expressions.Lee Justice0
The values are the same when i compare them doing step by step, I have no clue why it's skipping the If statement.lemster68 said:It looks like it might work. Single step forward one line at a time so you can see the values and the evaluation of the expressions.
Well, if even one number is mismatched five decimal places over I suppose it will evaluate to NOT TRUE. Try instead the Dist() function and use a value that is very small, like 0.5mm.Lee Justice0
Where can i find this function?lemster68 said:Well, if even one number is mismatched five decimal places over I suppose it will evaluate to NOT TRUE. Try instead the Dist() function and use a value that is very small, like 0.5mm.
Is it Instruction - Mathematics - Distance?0 -
It worked! Thank you!0
Hello,Be careful, Distance only give you the distance. It doesn't take care of orientation neither configuration.☑️2024 - RobotStudio® User Group0
