Remove apps from the Flexpendant
Hello!
I just started to try creating screens in ScreenMaker in the newest Robotstudio version. Right now I'm connected to a VC and transfered a project to the flexpendant. But now to my question, how do I remove the project from the flexpendant?
/erik
  • You have to remove the two dll files in the home directory.
    I can't delete them, "...could not be deleted"
    Found them in my C drive and it worked
  • I know this has been solved but a shortcut to delete this files is to close the Virtual FlexPendant - Right Click on the Home Dir in your system - Open Folder - Find and Delete the two .dll file from that directory and restart the system.
  • You only need to delete "TpsView.....dll"  and "TpsView....gtpu.dll" from Home and restart the system.
