RobotStudio getting started tutorials question
Hello, I am new to this forum and RobotStudio in general. I am on Module 4 of the Getting Started tutorials. In this module, they import a table and a engine block. When I go to import any geometry it is empty. Could someone help me locate the models, or possibly supply a link?
Thank you for your time
Had the same issue back then. You can continue without, but I think you find that stuff in the Add-In Tab and search for tutorial.
1 -
If you not found the files at RobotApps you can download them here:
https://abb-my.sharepoint.com/:u:/p/anders_spaak_se/ERomVZIiZpZGtdYgq-Jzk4IBfJ3y8hwXR-3j0WpXzrRumQ?e=IrM1Th
ABB Robotics1 -
Thank you for your help. I have another question in Module 5. I am using the latest version of Robotstudio, however the tutorial is from 2015. @ 3:12 in the tutorial, it says to press modify instruction. However, with this newer version of the software. I am unable to follow the instructions. What is my best option in this situation? Thanks0
Hi, you can download the files here:
https://abb-my.sharepoint.com/:f:/p/anders_spaak_se/EjzhaDT2madMuhi5r5tUtMcBqhs4FrwNA_LE45LwRg4Zgw?e=jiVpHeBest regards,
Tack så mycket, Anders.
The files are available in this post: https://forums.robotstudio.com/discussion/13184/getting-started-tutorial-4-objects
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
