Look at ABB S3 backup
Hi all,
I've stumbled on an old S3 backup, and I'm wondering if its possible to open it and see its contents.
This backup is in .ima format, probably made with FlexiDrive Floppyemulator.
I'm aware there would be two steps that should be made: first open the .ima file itself, and after try to open its contents.
I've tried some software to open the .ima file, but I get errors, and I don't know if this happens because Windows XP (the OS where I'm trying to do this) doesn't recognize the contents inside .ima file, or because the .ima file itself is damaged.
So, if someone have a hint about how to perform this - if possible - it would be great.
  • Hello,
    If this file is an image then test to open it with 7-Zip.
  • Hi, Denis. Sorry for the long delay.
    I've tried 7-zip as well, but didn't worked.
