Import robtargets from .CSV file?
sturner
Is it possible to import robtargets into RS station from .CSV file?
There was an addin (I think addin) some time ago to Importcoordinatefiles (that was what it was called) in such format. I played around with it for a little while to see how it worked. Not sure if it would work with current RS.Lee Justice0
Thanks for the information... how do you install this addin?
Most addins seem to install via 'install package' but I cannot find the .rspak file0 -
If you PM your email I can share from my google drive. It is several years old and seems to be for 5.60.Lee Justice0
- 367 IRC5
- 858 RAPID Programming
