How to read/write RAPID?
g327igor
g327igor
edited December 2020 in RobotStudio
Sorry, can somebody explain
1. What means "myString"
RapidData rd = _controller.Rapid.GetRapidData("T_ROB1", "myModule", "myString");
2. what I should put inside the Textbox for writing RAPID ?
rapidString.FillFromString( textBoxString.Text);
I need just an alive example.
  • 1. The variable inside the module you are calling
    2.
  • I believe the manual for the Robot Application Builder would be of use to you, specifically section 5.5.3.1. "Working with Rapid Data"
