Configuring Controller for I/O system
Armbross
How do I make signals in the I/O system of controller, I tried following http://websvrnu.his.se/au113g/smartcomp3/smartcomp3.html & https://www.youtube.com/watch?v=1vnxYdN_cLQ&t=56s but when I click the signal in I/O simulator the output does not change to 1? https://gofile.io/d/91Nkrj (< attached the Pack & Go file)
nvm mind I got it, just switched controller to Station Logic as the two signals as digital input0
