Closest Object problem
Armbross
Hi, I'm trying to use closest Object to do Pick N Place. I have the robot in a robot cage Cell. I'm using closest object in smart component to pick up a Object, but RS picks up the cage instead of the my intended object.
The cage is considered an object according to closest object. I want the smart component to ignore it. Is there a way to do so?
https://gofile.io/d/ylZGxi Heres is my file. Trying to do pick n place without picking up the cage in the process.
Hope to receive advice0 -
I did not download your project but you may want to uncheck "Detectable by Sensors" for your cage object.
I have done it, but closest object does not attach the target to gripper because the child is always changing even after I uncheck "Detectable by Sensors" for the other objects not involved in the pickNplace0
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 824 RAPID Programming
- 9 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
