Omnicore view & edit value in flexpendant
Tompanhuhu
in OmniCore
I have found a button to view rapiddata values in the flexpendant.
But all fields are 'read only'. Is there any way to make it possible to change these values from the flexpendant like how the IRC5 controller worked?
☑️2024 - RobotStudio® User Group
What type of data are you trying to edit and how is it declared?It seams that for persistents it's possible to edit only initial value, not current value.Also you can not edit data, if it's declared in READONLY module.
-1
