DropDown.enabled bug in Omnicore App SDK
Fritz
There seams to be bug in javascript library with "enabled" property of DropDown component. It will generate error on html page:
"Document Load event routine failed. >>> TypeError: Unable to get property '_enabled' of undefined or null reference"
Code in Load event, that generates it, is following:
drpLoggingLevel = new FPComponents.Dropdown_A();
drpLoggingLevel.model =
items:
"Silent",
"Brief",
"Verbose",
"Debug",
drpLoggingLevel.selected = 2;
drpLoggingLevel.onselection = doOnLoggingLevelChange;
drpLoggingLevel.enabled = false; // bug in API ? - will generate error
drpLoggingLevel.attachToId("LoggingLevelDropdown");
OK, solved it immediately by myself.Writing "enabled" property must be AFTER attaching component to DIV element:drpLoggingLevel.attachToId("LoggingLevelDropdown");drpLoggingLevel.enabled = false;
It might be still bug, as all other components will work either way.
But at least workaround for now.
