40223 Execution error
I am using two ABB robots with ATI force/torque sensors. Recently, I removed one of the sensors from one robot and I created a new system using system builder. Since then, when I run a simple program just to activate force control, it stops at the very first line, which is FCLoadID command. And I keep getting this error code 40223 which says:
40223, Execution error
Description
The execution of task T_ROB2 has been stopped by a runtime error.
Consequences
The program execution is immediately halted.
Probable causes
The program error is considered UNRECOVERABLE so no error
recovery attempt by an error handler routine (if used) was allowed. The
actual cause of the error may vary, and is likely to be specified in an
event log message logged simultaneously as this one.
Recommended actions
1) Check other event log messages logged simultaneously to determine
the actual cause.
T_ROB2 is the one with the F/T sensor. Any input will be very much apprecited.
Thank you,
Luigi
Description
Consequences
Probable causes
Recommended actions
the actual cause.
Thank you,
Luigi
Hello,Error code 40223 is not a root cause, Besides it is more like a result.As it is described in the Manual, you need to check out other event logs which are happened at the same time with 40223.BR,0
Did you find some solucion. I have same issue.0
What else is in your event log when error 40223 occurs?0
