RS 2020.4 CANT TYPE FAST
I found a problem with RS2020.4. There is no way to type fast on a big module. All the typing goes with lag, this is so annoying. tested on a clean module, where works good, but type on a module with already 2k lines goes so slow. Please help or fix this.
https://youtu.be/Y9y3JAzPD8Q
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
That has already been discussed and, supposedly, the fix is coming for that issue. See this thread if you like:
https://forums.robotstudio.com/discussion/12395/2020-2-bugs#latest
Lee Justice1
This discussion has been closed.
- 367 IRC5
