RS SDK Render both sides surface property
msalminen
Hi, in RS - Graphic Appearance dialog you can change part/body/face property: Render both sides.
How this can be done with C# code in RS SDK? I haven't found any properties or methods for this.
Mika
Mika
Hello msalminen,
Unfortunately, the change of this property is not supported via RS SDK.Best regards,Maxim
Thanks, now I can stop searching for it. Maybe in future it will be there.
Mika0
