Out of virtual memory
zsessenw
We have a robot cell with 9 robots of various types in it. All have IRC5 controllers. Once every month or so, one of them will get an error that will pop up saying that the controller has run out of virtual memory then does an automatic warmstart. The mass storage only uses 1/3 of its space, RAPID memory is 90% free, and the system memory is mostly free. I am checking after the robot did its warmstart, so it may have cleared up something. I have seen this happen on 4 of the robots in the cell. Each time I cannot find any memory that is full. Does anybody know where to see the virtual memory? Is there a way automate the memory clearing itself without affecting production?
Do your controllers have a custom GUI made with the FlexPendant SDK? If you do not properly call the Dispose() method, it will cause memory leaks and eventually lead to the error you described above. Check out the Application Manual - FlexPendant SDK0
Thank you for the response xerim! I am not familiar with the SDK. Is there a way to tell if there is a custom GUI or anything created from the SDK? I do not see any obvious graphical differences on the pendant0
Do you have an HMI screen on your controller?0
No. The only interface is on the flexpendant through TPWrite instructions during error handling. These get erased every cycle0
