sharing modules
Have 2 tasks one non motion other motion
In the non motion Task I have a program module set as Shared under Automatic Loading - works fine and I can see all the module objects in the other motion Task (after a P-Start) been working fines for ages
But today I wanted to share a program module from the motion Task to the other - used same Automatic Loading settings but CANNOT see its objects in the other non motion Task, after p-Start
Anyone know what could be wrong?
  • EricH
    EricH
    edited February 2021
    What settings do you use? I use only shared and all the others are deactivated.
  • What do you mean by "objects"?  Data declarations?  If so, they must be declared as PERS.
    Lee Justice
