IndReset not reseting axis to correct position
Hello all,
I have a system with two robots and additional servo axis MU400. MU400 is driving a rotating table. When the movement is finished the axis stops at lets say at 20.000°. I am trying to use the function to reset position inside 360° and when doing this I am getting incorrect axis positions. Even in simulation it seems like axis is jumping to incorrect position (should have stayed in the same place, no?).
System is multimove with independant axis.
RW is 6.11
Transmission settings are set and position on the flex pendant is showing the correct value when rotating the table. I didn't set Transmission Gear High and Low. Only the Gear Ratio.
To test the situation I drove the axis to 5° and then used IndReset. The axis skips to -225°.
After moving the table to 0°, the table end up ofcourse in incorrect position. In the picture at the bottom there is a screenshot of flex pendant showing the test result.
The code I used to test is practicaly copy paste from RAPID manual:
TPErase;
IndCMove M7DM1, 1, 0;
WaitUntil IndSpeed(M7DM1, 1, \ZeroSpeed);
WaitTime 0.2;
pTempJointTarget := CJointT();
TPWrite "Before IndReset: " \Num := pTempJointTarget.extax.eax_a;
TPReadFK FK, "", stEmpty, stEmpty, "Continue", stEmpty, stEmpty;
IndReset M7DM1, 1 \RefNum := 0 \Fwd;
TPWrite "After IndReset: " \Num := pTempJointTarget.extax.eax_a;
MoveExtJ Home, vrot100, fine;
TPWrite "After MoveJ to Home: " \Num := pTempJointTarget.extax.eax_a;
What am I doing wrong?
  • Hello again,
    Did some measurements today. Looks like the modulo is 230. or am I missing something? I am totally lost :)
    Before IndReset
    After IndReset
    -370,32
    -139,592
    -360,029
    -129,301
    -250,056
    -19,3278
    -239,997
    -9,997
    -230,029
    -230,029
    -5,01541
    -5,01541
    5,00713
    -225,721
    10,128
    -220,6
    20,0196
    -210,709
    30,0994
    -200,629
    40,0126
    -190,715
    50,0452
    -180,683
    100,156
    -130,572
    150,087
    -80,6415
    200,038
    -30,6905
    225,037
    -5,69095
    230,032
    -0,696578
    235,002
    -226,455
    240,013
    -221,443
    250,01
    -211,446
    300,014
    -161,442
    350,000
    -111,456
    360,01
    -101,446
    370,078
    -91,3782
    460,009
    -1,44746
    469,998
    -222,186
  • Hello all,
    I figured it out...
    It was actualy the configuration parameters GearHigh and GearLow.
    Looks like IndReset is using Those two parameters to calculate new axis position and not just GearRatio.
    Best regards.
