EgmClock message does not represent UNIX time on RobotStudio
The definition of EgmClock
in proto/egm.proto is
message EgmClock // Time in seconds and microseconds since 1 Jan 1970 { required uint64 sec = 1; required uint64 usec = 2; }
Below are headers of EGM messages sent from RobotStudio on my system:
header { seqno: 352216 tm: 28397221 mtype: MSGTYPE_DATA } feedBack { joints { joints: 0.00025089801056310534 joints: -0.010418600402772427 joints: 0.03861050307750702 joints: -0.0001342049945378676 joints: 45.01199722290039 joints: -0.0667094737291336 } cartesian { pos { x: 1216.9378662109375 y: 0.0046911695972085 z: 1187.1817626953125 } orient { u0: 0.3823593258857727 u1: -0.0005403859540820122 u2: 0.9240135550498962 u3: -0.00022283525322563946 } euler { x: -179.93319209849528 y: 44.95977143802771 z: -179.90533858705996 } } time { sec: 28397 usec: 216500 } } ...
The time data sec: 28397
does not look like "time in seconds and microseconds since 1 Jan 1970".
This happens on RobotStudio only; with the real robot the timestamps are OK.
Is this a RobotStudio bug? If yes, where should I report it for it to be fixed?
28397 seconds = 0.32866898 days
Perhaps it starts counting once RobotStudio is launched?0 -
This is the response that I got from ABB support:
according to our support EGM is not supported by RS this is why You notice different behavior of EGM clock.
I checked with RobotStudio R&D and they advised that RobotStudio doesn't do anything with EGM, so it is not a bug with RobotStudio, instead it is not designed to work with it.
It is surprising then that RobotStudio does execute EGM RAPID commands, and even does send EGM data.
The issue seems to be fixed in RobotStudio 21.2.9526.0 -- the timestamps look like UNIX time now.
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
