Monitor Speed and Torque of joints
AlvaroV
Hi there!
I am trying to monitor the speed and torque of each joint of my robot but I can't manage to find those signals in the Signal Analyzer, only the TCP speed. ¿Is there a way of monitoring those values?
Thanks in advance,
Alvaro
Thanks in advance,
Alvaro
Which version of RW? RW 6 introduced GetMotorTorque
Exactly, I have RW6. Where do you look for those functions?0
Hey there!
For what I've seen, GetMotorTorque is generally used to compared at a given time the torque of an axis and use it to trigger an event. However, I intended to plot the torque values of each axes, does someone know a smart way to do that?
I've tried with TestSignDefine but I have no idea as for how to access the data that is being monitored.
Thanks in advance,
Alvaro0 -
You need to use TestSignRead with TestSignDefine0
All rigth, I've added both functions to my RAPID code, but now then, where can I see the resulting data in the channel?
Thanks for your response, I recently started working with RobotStudio so I appreciate the help.0 -
Create a NUM variable to store the torque value, then write the value to the teach pendant using TPWrite. This should work with GetMotorTorque as well.0
Thanks a lot!
I ended up using Write instead of TPWrite in order to export it to Notepad. I used a timer that triggers each 0.1s and calls a TRAP where I read the torque and write it. However, 0.1seconds isn't the most accurate sampling time but it looks like I can't reduce it. Do you know a smarter way of reading (and then writing) the torque value?
Thanks in advance,
Alvaro0 -
You could set up 6 analog outputs and use a for loop to iterate through the TestSignDefine and TestSignRead..here is a very incomplete example:
FOR ii FROM 1 TO 6 DO TestSignDefine ii, 4002, ROB_1, ii, 0.004; ENDFOR
and thenVAR num torques{6}; WHILE TRUE DO FOR ii FROM 1 TO 6 DO torques{ii} := TestSignRead(ii); ENDFOR SetAO motorTorque1, torques{1}; SetAO motorTorque2, torques{2}; SetAO motorTorque3, torques{3}; SetAO motorTorque4, torques{4}; SetAO motorTorque5, torques{5}; SetAO motorTorque6, torques{6}; WaitTime 0.004; ENDWHILE<br>1
