Integrated vision and virtual controller
Dedex
Hello guys,
i have abb cognex 7000 series camera in my home. I want to make practice with integrated vision. I heva tried everything connect for camera but i dont. i saw the this code,
<?xml version="1.0" encoding="ISO-8859-1" ?>
<VC_NETWORK_DEF>
<PORT name="LAN">
<IPaddress>10.46.77.126</IPaddress>
<SubnetMask>255.255.252.0</SubnetMask>
</PORT>
<PORT name="SERVICE">
<IPaddress>169.254.0.12</IPaddress>
<SubnetMask>255.255.255.0</SubnetMask>
</PORT>
</VC_NETWORK_DEF>
I tried .Fail.
I think i miss some point.
Please can anybodey tell me step by step how i connect the sensor my virtual controller.?
Maybe video or with photos? Like ,go to internet setting->select Tcp/ıpv4-> write this ip and mask-> vs vs ...
I saw the lots of topic for this issue.
Photo or video archivewill be very usefull for everybodey.
thanks.
I tried .Fail.
thanks.
Post edited by Dedex on
xerim said:The setup process is very well documented in the Application Manual - Integrated Vision
i will use VC. I dont have any irc5 controller at home:)
This process is also documented in the manual
- 367 IRC5
- 858 RAPID Programming
