Seconds to Time
xerim
I have this function that converts seconds (num) to hours and minutes (num:num).
It works great until you input a time in seconds that is less than 10 minutes into the hour, for example 5:04 or 7:09 would end up being printed as 5:4 and 7:9 respectively. I know this has something to do with the inputs being divisible by 60 so the MOD returns 0 as there is no remainder..how can I force it to add a 0 to complete the time format?
FUNC string SecondtoTime(num s)
VAR num seconds:=0;
VAR num minutes:=0;
VAR num hours:=0;
s:=Round(s);
IF s>=60 THEN
minutes:= s DIV 60;
seconds:= s MOD 60;
ELSE
seconds:=s;
ENDIF
IF minutes >= 60 THEN
hours:= minutes DIV 60;
minutes:= minutes MOD 60;
ELSE
minutes:=minutes;
ENDIF
RETURN NumToStr(hours,0) + ":" + NumToStr(minutes,0);
ENDFUNC
In other words, I am looking for a RAPID command that allows me to prepend a 0..I can't seem to find anything in the manual that allows you to do this.0
Instead of DIV try minutes:= s / 60;0
Thanks for the suggestion, I implemented it but the issue with the missing 0 for minutes below 10 persists.0
I have found the solution now, the trick is to add another IF statement at the bottom of the function. Instead of:
You need:
IF minutes < 10 THEN
RETURN NumToStr(hours,0) + ":" + "0" + NumToStr(minutes,0);
ELSE
ENDIF
