External Axis Wizard for Newest Version of RobotStudio (June 2021)
I recently updated to the newest version of RobotStudio (version 21.1.9443.2, updated yesterday) from RobotStudio 2020 (not sure of exact version). I had a working External Axis Wizard add-in on my studio 2020 version, but when I updated studio, the External Axis Wizard add-in was no longer compatible (it said it required version 20.99.99 or lower). Is there a download for an External Axis Wizard add-in that is compatible with studio 2021, or will I be stuck redownloading studio 2020 for now? If there is another solution, please let me know.
Thank you!
Thank you!
Hello there,
You can get the latest version of External Axis Wizard via RobotStudio -> Add-Ins tab in the ribbon, then RobotApps, and use the search for External Axis Wizard.
Maxim
