ABB root jogging speed (through HMI)
Dear ABB family,
For my graduation project, i have to jog ABB-robot (IRB660) via the HMI. I also have to adjust the speed manually. Directions x y z is working well.
I use the speed.tcp to adjust movement speed.
Now i have to jog axis 4, the rotation.
How can i adjust de rotation speed? Which movement command i should use MoveJ of MoveL?
I hope that my question is clear for you. I can send my code if it is needed.
Thank you in advance!
Selen Ersoy
  • Try the RelTool function within a MoveJ  command.
    You can make the Robtarget the same as where the robot is currently , then use the rotation round the appropriate tool axis via the Reltool.
  • @graemepaulin Thank you alot. I think this is exacly what i was looking for. With Reltool, i dont have to calculate quaternion to euler and back. just give the offset in degrees.
    Thank You!!
  • Micky
    Micky ✭✭✭
    The speed of the reorientation is set via the component "v_ori" in the data type "speeddata" independent of the used movement command.
    Quote from the manual of the chapter "speeddata":
    v_ori (velocity orientation)
    Data type: num
    The reorientation velocity of the TCP expressed in degrees/s.
    If a stationary tool or coordinated external axes are used, the velocity is specified relative to the work object.
