Rapid code Examples for Ethernet/IP
Hi we have an ethernet/ip adapter device connected to ABB IRC5 controller. Can someone show me the code example in Rapid to read/write an instance in the adapter device from rapid code. I saw an example in Ethernet/IP manual but couldn't understand where the ip address of device is mentioned and how the data is sent.
- 367 IRC5
- 858 RAPID Programming
