Import HMI recipe / Analog signals from file
lucgar
I have made smart components that moves to certain values depending on analogue inputs. These values depend on which product is currently being used in the process. Is there any way to import these recipes or maybe a analog signal list from a file? I was thinking an excel file with the name of the analogue output and the value.
HI Lucgar,
It is possible to read plain text files in rapid.But maybe you need to explain more in detail what you want to do, and how you have done so far for more help
- 367 IRC5
- 858 RAPID Programming
