VSTA
Good Day,
I am having issues getting VSTA to work in RS 5.08. The following error occurs each time I attempt to open VSTA.
RobotStudio .NET exception dump
Base exception:
Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
at ABBInternal.VstaServices.VstaIntegration.EnsureDTE()
at ABBInternal.VstaServices.VstaIntegration.ShowIDE()
at ABBInternal.VstaGUI.VstaSetup.btnIDE_ExecuteCommand(Object sender, ExecuteCommandEventArgs e)
at ABB.Robotics.RobotStudio.Environment.CommandBarButton.RaiseE xecuteCommand()
First, try running this command (Start -> Run...)
"C:Program FilesMicrosoft Visual Studio 8Common7IDEVSTA.exe" /HostID RobotStudio /setup
If that doesn't help, run the RobotStudio Support Tool, go to the "Fault Log Files" tab and click "Perform Scan". If there is a file called "VSTA.rserrors", please post the contents here and we'll take a look at it.
Johannes Weiman
Still no worky
Here is the fault log for VSTA.rserrors
===== VSTA Exception =====
3/6/2007 1:22:44 PM
Base exception:
at VSTADTEProvider.Interop.VSTADTEProviderClass.GetDTE(String bstrHostID, UInt32 dwTimeout)
at ABBInternal.VstaServices.VstaIntegration.EnsureDTE()0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
