how to find the correct option to add to mediapool have tried a few things ?
  • I don't have 6.11.01 installed right now but here is where that version can be found.
    C:\ProgramData\ABB\DistributionPackages\ABB.RobotWare-6.11.2019\RobotPackages
    You may need to update to the 2020 published version if you only have the 6.11.00 showing up.
  • That would be the addins tab in robotstudio.
    Lee Justice
  • Have sent you a private message with the option disc.
  • Thanks to all replies, I haven't had a chance to try yet but will let you know asap
