how to find the correct option to add to mediapool have tried a few things ?
Stigsson
I don't have 6.11.01 installed right now but here is where that version can be found.
C:\ProgramData\ABB\DistributionPackages\ABB.RobotWare-6.11.2019\RobotPackages
You may need to update to the 2020 published version if you only have the 6.11.00 showing up.
That would be the addins tab in robotstudio.Lee Justice0
Have sent you a private message with the option disc.1
Thanks to all replies, I haven't had a chance to try yet but will let you know asap0
