Teach target with a macro
I need to make an event that teach a tagets each time i trigg an Output from my rapid code.
How du i du that with VB.
"Set t2 = Application.ActiveStation.Targets.Add"
makes a new target but it have to be with the CRobT().
Please help.
Best regards klaus
Klaus Soenderhegn
www.cadalysator.dk
Like thist2.Transform = Application.ActiveStation.Mechanisms(1).ActiveToolFrame.Tran sform
Where 1 is the index of the mechanism in the station, can exist more than one depending how your station looks like.
ActiveToolFrame is the one you choosen in the elements toolbar.
You could also use ToolFrames(x) if you want to control which toolframe to use if you have several.Per Svensson
Consat Engineering0 -
hei Per thanks alot it works in rs3.2 with this code
Dim t1 As Target
Dim trans As New Transform't1 = trans '
Set t1 = Application.ActiveStation.Targets.Add
trans.Position = Application.ActiveStation.Mechanisms(2).ActiveToolFrame.Tran sform.Position
trans.Orientation = Application.ActiveStation.Mechanisms(2).ActiveToolFrame.Tran sform.Orientation
'Application.ActiveStation.Mechanisms(0).ActiveToolFrame.Tra nsform
t1.Transform = transIf i use the same code in vsta a get errors on these names that is underlined.
Dim t1 As target
Logger.AddMessage(New LogMessage("Macro_Sample1 output window message."))
i have improted these references.
Imports System
Imports ABB.Robotics.Math
Imports ABB.Robotics.RobotStudio
Imports ABB.Robotics.RobotStudio.Stations
Imports ABB.Robotics.RobotStudio.Environment
i must miss somethings
Best regards klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Hi Klaus
The object model in RS5 is totally different from the one in RS4.
Take a look at the vsta example supplied there is a macro for creating targets.
You could also take a look on this topic where I have written some info regarding creating addins for RS5, may give you some hints on the object model (haven't tested them on RS5.08 but I think the object model haven't changed since then)
http://forums.robotstudio.com/forum_posts.asp?T ID=621&PN=9Per Svensson
Consat Engineering0
- 858 RAPID Programming
