IRC5 teachpendant will not foward or run to a cursor selected position
Hello Abb world,
   I am new to ABB, we just got an IRC5 single. We are unable to foward or run to a cursor selected position. Eveverything else is working. No alarms and can jog robot manually. When we put pp to cursor on a move line in any routine, everything functions as it should but wont foward when pressing foward button. Does anyone have an idea of what this could be?
  • lemster68
    lemster68 ✭✭✭
    Answer ✓
    The entire membrane could be bad, or disconnected inside.  Best to see about a warranty replacement or service call under warranty.
    Lee Justice
  • Can you PPtoMain?  ARe there any syntax errors?  Debug, check program.
    Lee Justice
  • I can PPtoMain. Checked program, no errors.
  • Please elaborate what you mean by "IRC5 single".  A single robot connected to controller or single axis connected to controller?
    Lee Justice
  • A single robot to controller and only 1 robot task.
  • So what happens if you put the program pointer to a non-motion instruction?  How about when you press the start button?  Or the backwards button?  Maybe the forward button is bad.
    Lee Justice
  • The start or backward buttons will not work. With no errors we are starting to think its wiring inside pendant
  • We just received a new pendant. Everything is working. Thanks for the help
  • Excellent!
    Lee Justice
