Create new controller with options
Klaus
I have created a new controller but can,t use open command in rapid because the controller is missing option file and seriel channel.
In RS 5.07 it was possible to add options with viatuel key.
How do i do that in rs 5.08. Cant see anything in the help file
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Use the System Builder found in the Controller menu to modify your system.Per Svensson
Consat Engineering0
