Read Only While Using Dark Theme
I like the dark theme that was added to robotstudio, however when on a live robot while you do not have write access the text editor has a grayish screen over it that isn't the most comfortable to look at. Is there a way to keep the read-only stipulation from changing the background color of the text editor?
Hello there,
I've reported this to R&D.
Thanks for bringing it to our attention!
Hello again,
I've received word that this issue will be resolved in RobotStudio 2021.3 release.
Maxim
