Multimove
What is the diffenence between MultiMove Coordinated and MultiMove Independent and when should I use either of them?
  • Hi
    Independent is like if you have 2-4 single robot systems. They just run on the same controller.
    Coordinated do you choose if you want the robots to cooperate. Like if one robot is holding a workpiece that the other robot works on and you want to have syncronized motion.
    If you like to know more I suggest that you get in contact with your ABB salesmen and ask for the MultiMove Application Manual.
    Per Svensson
    Consat Engineering
