sharing a variable between 2 robots
Toby
I have searched and not found the answer... How do I share a PERS between two robots? They both have their own controls so not sharing a pendant... Thanks
Best Answers
They would have to be connected to an industrial network together, or linked by a PLC. A PC running some application protocol could serve as a go between as well. What kind of PERS data type? If it is something simple like bool, just use an output/input setup.Lee Justice0
thank you... that is actually how Im doing it just thought there might be another way....0
