sharing a variable between 2 robots
I have searched and not found the answer... How do I share a PERS between two robots? They both have their own controls so not sharing a pendant... Thanks
Best Answers
  • lemster68
    lemster68 ✭✭✭
    Answer ✓
    They would have to be connected to an industrial network together, or linked by a PLC.  A PC running some application protocol could serve as a go between as well.  What kind of PERS data type?  If it is something simple like bool, just use an output/input setup.
    Lee Justice
  • Toby
    Toby
    Answer ✓
    thank you... that is actually how Im doing it just thought there might be another way....
