Discussion Title
                    rf_iasys
            Post edited by rf_iasys on
            Hello guys,
Apparently there's a difference in refresh rate when having simulation started and not.
Take a look at this entry in the RobotStudio manual:
Hope this information helps!
            Hello,I never used this SM, but have you got these times when Simulation is Running or Stopped?☑️2024 - RobotStudio® User Group1
            Post edited by rf_iasys on0
            Hi, just came over this thread. We are currentyl trying to connect Simit, ABB RobotStudio and Game4Automation. Everything works so far but as mentioned above cycle time between ABBRobotStudio is about 1s, what is to much for smooth movements. Simit can update the SHM in 1ms why is ABBRobotStudio updating so slow. Is there any way to change the update rate and make it faster?
Thanks and Best regards
Thomas0
 - 363 IRC5
 - 81 OmniCore
 - 853 RAPID Programming
 - 31 AppStudio
