Load a shared RAPID module using RWS
mkatliar
Dear colleagues,
With RWS one can load a RAPID module into a specified task: https://developercenter.robotstudio.com/api/rwsApi/rapid_task_loadmod_page.html
There are, however, shared modules, which do not belong to a specific task but are shared between all tasks. How can I load a shared module with RWS?
You must enable/select the option "Shared" inside the Configuration - Automatic Loading of Modules - then on the respective Module. See attached.0
- 364 IRC5
- 82 OmniCore
