MultiMove question
I want to pick a paper from the ground with robot #1 and give it to robot #2. I don't know how to do this though becasuse the workobject of the paper is attatched to robot #1. When I try make targets on the workobject with robot #2 the targets appear under wobj0. How am I supposed to solve this? I'm a student by the way.
You need to define which workobject that is the active one(where targets should be created), use the elements toolbar.Online training link
http://www.robotstudio.com/Per Svensson
Consat Engineering0
- 5.4K RobotStudio
- 384 UpFeed
- 15 Tutorials
- 12 RobotApps
- 290 PowerPacs
- 405 RobotStudio S4
- 241 ScreenMaker
- 2.7K Robot Controller
- 283 IRC5
- 44 OmniCore
- 3 RobotStudio AR Viewer
- 746 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
