I have a problem in the robot need to activate the joging and other items as it is not active like b
The controller is currently in a "system failure" state. In order to recover it, click the menu step by step as follows. Restart -> Advanced -> B-Start -> OK -> B-Start. Then, it mostly returns to normal state when B-Start is finished. Otherwise, you need to check other reasons.0
