Exception when creating a new virtual controller
RobotStudio .NET exception: Das aufgerufene Objekt wurde von den Clients getrennt. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED))
Base exception: COMException
   at RobotStudio.Services.RobApi.Interop.IRobVC.IsRunning(Int32& bRunning)
   at RobotStudio.Services.RobApi.RobVcFactory.<WaitUntilServerRunning>d__7.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at RobotStudio.Services.RobApi.RobVcFactory.<>c__DisplayClass4_0.<<StartVC>b__0>d.MoveNext()
   at RobotStudio.Services.RobApi.RobVcFactory.<StartVC>d__4.MoveNext()
   at RobotStudio.Services.Controller.ControllerService.<StartAndWaitForConnectionAsync>d__34.MoveNext()
   at RobotStudio.Services.Controller.ControllerService.<StartAsync>d__32.MoveNext()
   at RobotStudio.Services.Controller.ControllerService.<Start>d__31.MoveNext()
   at ABBInternal.Controller.StationVirtualControllerManager.<StartNewController>d__16.MoveNext()
  • Hello,
    To troubleshoot this issue, please contact your local ABB and provide the report via RobotStudio Support Tool.
    Thanks!
    Maxim Riabichev
    PC Software Support Engineer
