The type or namespace name 'Modules' could not be found
Hello, I trying this example from flexpendan sdk, And I got this error while trying to compile:
Error    1    The type or namespace name 'Modules' could not be found (are you missing a using directive or an assembly reference?)    C:\Users\W7\Documents\Visual Studio 2008\Projects\TpsViewIRC5WartsilaApp\TpsViewIRC5WartsilaApp\view.cs    184    18    TpsViewIRC5WartsilaApp
This is the exampled extracted from SDK help
private int CountRoutines(Controller c)
    int result = 0;
    Task[] tasks;
    try
        tasks = c.Rapid.GetTasks();
        Modules modules;
        // Iterate tasks
        foreach (Task t in tasks)
            // Get all modules of the task
            modules = t.GetModules();
            Routines routines;
            foreach (Module m in modules)
                // Get all routines of the module
                routines = m.GetRoutines();
                result += routines.Lenght;
    catch (GeneralException ee)
        // TODO: Add error handling
    catch (System.Exception ee)
    return result;
Any Idea?
Thanks for help
Jorge Turiel
  • Hi Jorge, the data types Modules and Routines don't exist.
    The methods getRoutines and getModules return an array.
    Here is the correct code.
                int result = 0;
                Task[] tasks;
                try
                    Module[] modules;
                    // Iterate tasks
                        Routine[] routines;
                            result += routines.Length;
                return result;
    //U.
  • Thanks for your help, It's works
    /J
    Jorge Turiel
