Name of Backup folder
Hi Team,
Is there any way I can read the latest robot backup folder name?
Br/Sujoy
  • Anyone anyhelp?
  • The best recommendation I have for you is to set the Man-Machine communication parameters regarding backup.  You can set the desired name, path, whether name is unique or not and whether to prohibit the name change or not.  Then you will have a knowledge of where it will be located and what the name will be.  MMC.cfg in a backup, in syspar folder.  Read up on those in the system parameter manual.
    Lee Justice
