Add controller window - how to add controllers permanently
I have a question about Add controller window. I have a few robot controllers connected to Company Network, each one is connected by it's own router. The IP address is e.g. 172.30.15.1, and I have to add controllers manually by typing IP in Remote Controller window every time when i want to connect. It is possible to Add this IP's to Controller List permanently?
Thank you in advance for your help.
In jobs (on the controller tab) you have Device lists - this may help?1
The jobs tab can be found by going to -> add controller->add controller from device list->manage device lists.
1 -
Thank you guys! This is what I was looking for, it works great.
