How to access hd0a file by PC applicatin
Leon_dev
I want to access (read ,write,delete) files which stored hd0a\XA1 folder via PC SDK or webservice,is it possible?Now I can only access hd0a\system\home...
Thanks.
Thanks.
Does anyone have such experience?
You can use class filesystem. Example of my request:[CODE]controller.FileSystem.GetDirectory("ctrl:(BACKUP)$/" + backupDir, "D:\\Backup", true);[CODE/]If you want to access root-directory, change "ctrl:(BACKUP)$/" + backupDir to "ctrl:/hda0".This is working, but not the path2: "D:\\Backup", I hadn't figured out why, by now.
Hello derWestermann,
Can you please show screenshots or a manual reference that says that you can access path "ctrl:/hda0"?
I have not been able to find such source nor was I able to access anything below the HOME directory on my controller.
Thanks!
As I mentioned in Thread PC SDK 2021.3 FileSystem.GetDirectoryThis way, it works:[CODE]
controller.Backup("(BACKUP)$/" + backupDir);
do
this.Cursor = Cursors.WaitCursor;
System.Threading.Thread.Sleep(200);
this.Cursor = Cursors.Default;
} while (controller.BackupInProgress);
controller.FileSystem.RemoteDirectory = "/hd0a";
string recDir = "D:\\Backup\\" + backupDir;
string sendDir = "/BACKUP/" + backupDir;
controller.FileSystem.GetDirectory(sendDir, recDir);
[CODE/]
Great, thanks!
Thanks for your post.Do you mean that as long as I did the backup to hda0,I can access other files or folders at hda0 besides system\home?Just like an activation?derWestermann said:You can use class filesystem. Example of my request:[CODE]controller.FileSystem.GetDirectory("ctrl:(BACKUP)$/" + backupDir, "D:\\Backup", true);[CODE/]If you want to access root-directory, change "ctrl:(BACKUP)$/" + backupDir to "ctrl:/hda0".This is working, but not the path2: "D:\\Backup", I hadn't figured out why, by now.
I change "ctrl:(BACKUP)$/" + backupDir to "ctrl:/hda0",but the vs throw exception:”parameter name: path2 “ ,why is this?
