Event message 50143
Hello, we've made a simple little path in RobotStudio. The simulation of the path works perfectly in RS but when we try to execute every movement on the physical robot we get an error - event message 50143. What are we doing wrong how do we solve this?
Could be a couple of things and it's related to the axis configuration.
So did you run the path with configuration off(ConfLoff) in RS but not in the real robot?
Per Svensson
Consat Engineering0
- 87 OmniCore
- 42 AppStudio
