How to reset the booting up loop in Omnicore controller
After I did the restart the safety control in IRB 14050 I havent been able to boot the Omnicore controller or set up any connection and I ahve also  tried the method with start robotware system with no succes till date.
Is there any possibility to reset the controller via USB stick
