Creating Mechanism track
I am in need of a track with tavel length of 16.7m
The track is a RTT but the only standard length i RS is RTT 15.6
I have tryed using CREAT MECHANISM but i cant get it to work.
HELP HELP
Dept manager robot welding
Kez@hardi-international.com
What isn't working???Per Svensson
Consat Engineering0 -
well when i go in to "create mech" i have chosen External Axis.
i need to specify links and doubleklik on LINKS.then i need to select a part and it is here it is difficult for me.
A dont have any trackparts to select???
I need the the track and the carriage but dont know how to find them??
Kent Zibrandtsen
Kez@hardi-international.com0 -
If you go to
www.abb.com/robotics and select
Application Equipment & Accessories and then Track motion you will find 3d models under each type.Per Svensson
hi
i have tryed downloading the files For RS 5.07 but it is library files??
Kent Zibrandtsen
You should download acis files(*.sat) and import into RS.Per Svensson
I cant see any Acis files in there.
It is only RSlib-files theres in this location under RTT robotstudio 3_2 and RTT Robotstudio 5_07
Kent Zibrandtsen
What type of track are you looking at exactly???Per Svensson
i need a track a RTT marathon with travel length of 16.7 mKent Zibrandtsen
Here is a RTT marathon including cfg-file modified to 16.7 m.
ABB Robotics0
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
