Collision avoidance max tracked objects?
Background: I am working on a project where there are a number of fixed place items we would like to track for collision avoidance. I have added 10 objects to track of varying geometric complexity. The add button is now greyed out so it seems I cannot add any more objects to track. I cannot find any details about the limitations of collision avoidance and or a max number of tracked objects or object pairs.
Questions: Does anyone have any further detail about collision avoidance, the limitations and possible work arounds?
Thank you,
Steve
  • Steve, try putting all your objects / grouping some objects into Component Groups then drag it into your collision set.
    Keep in mind the more things you track & the further out you set your near-miss you will slow down your program.
