Program Pointer Moved to Routine | Safety Guard Stop State
great
Hi there,
I need help. When I run the simulation before creating a Virtual Controller from layout the LineMover moves the object normally but as soon as I create a VC the object does not move and the simulation stops but itself. But I did not experience the same problem on a different PC I was using. See the images below
What are you calling simulation setup, show screenshot.
Also, what are you calling in RAPID?0
